Mills Boiler
ajeddie
ajeddie Member Posts: 1
I am looking at aMills series 34 1074 9 section hot water boiler, how many BTU's is this rated for ?
  • icesailor
    icesailor Member Posts: 7,260
    Mills Boiler:
    I don't know but if it is a "Mills" only, it is big commercial and not listed anymore. One needs more information.
    Where is it?
    What is it firing with? Gas or oil?
    Steam or hot water?
    Doesn't it have a name plte on it somewhere? If it is a big commercial boiler, it must have a ASME plate on it to be legal and insurable.
    More info needed.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Contact Smith after the holidays they
    may still have archives. As said there need to be a rating plate. Why do you need to know the rating on this boiler? I saw you are running it as a hot water unit. If that is the case you would need a heat loss if you are thinking of replacing it. If you are choosing a burn rate for the oil a heat loss would be helpful too.
    cell # 413-841-6726
  • Mike Kusiak_2
    Mike Kusiak_2 Member Posts: 602
    Mills series 34
    Found an old datasheet on the Mills 34-9 (hand fired) and 340-9 (automatic fired}
    Steam net rating     3200 Sq/ft
    Steam gross rating  4475 Sq/ft
    Water net rating       5120 Sq/ft
    Water gross rating   7160 Sq/ft
    Heating surface   247.5 Sq/ft
    Oil firing rate      9.57 Gal/hr
    So if you multiply 140,000 btu/ gal of oil x 9.57 you get a max input of 1.4 million BTU.
    Or, take 4475 Sq/ft steam gross x 240 BTU/Sq ft you get 1.074 Million BTU gross output.
    Probably not exact, but at least should get you into the ballpark.
