Mills Boiler
ajeddie
Member Posts: 1
I am looking at aMills series 34 1074 9 section hot water boiler, how many BTU's is this rated for ?
Mills Boiler:
I don't know but if it is a "Mills" only, it is big commercial and not listed anymore. One needs more information.
Where is it?
What is it firing with? Gas or oil?
Steam or hot water?
Doesn't it have a name plte on it somewhere? If it is a big commercial boiler, it must have a ASME plate on it to be legal and insurable.
More info needed.0 -
Contact Smith after the holidays they
may still have archives. As said there need to be a rating plate. Why do you need to know the rating on this boiler? I saw you are running it as a hot water unit. If that is the case you would need a heat loss if you are thinking of replacing it. If you are choosing a burn rate for the oil a heat loss would be helpful too.Cost is what you spend , value is what you get.
cell # 413-841-6726
Mills series 34
Found an old datasheet on the Mills 34-9 (hand fired) and 340-9 (automatic fired}
Steam net rating 3200 Sq/ft
Steam gross rating 4475 Sq/ft
Water net rating 5120 Sq/ft
Water gross rating 7160 Sq/ft
Heating surface 247.5 Sq/ft
Oil firing rate 9.57 Gal/hr
So if you multiply 140,000 btu/ gal of oil x 9.57 you get a max input of 1.4 million BTU.
Or, take 4475 Sq/ft steam gross x 240 BTU/Sq ft you get 1.074 Million BTU gross output.
Probably not exact, but at least should get you into the ballpark.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
