Asbestos
456 Member Posts: 1
I have asbestos on my steam pipes is there anything that they use to cover the pipes, with out removing the asbestos. Thanks tom
  • Big-Al_2
    Big-Al_2 Member Posts: 263
    edited November 2010
    Fabric
    Mine were wrapped in a couple of layers of cloth and then the cloth was saturated with paint . . . almost like they are in a plaster cast.   Best to let somebody who is properly trained do the job.
  • Steve_210
    Steve_210 Member Posts: 647
    re
    na bi ag caint
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,643
    I get it.
    Retired and loving it.
  • crash2009
    crash2009 Member Posts: 1,478
    I had to google it
    I get it now
  • na bi ag caint
    you could get the foil-backed, thin fiberglass insulation from the big-box store, and cover over what you have on the pipes now, secured with foil backed sticky tape. you would have to be well protected clothing-wise, and wear a breathing mask. remember that it is the removal/disposal which needs a special licence etc.
    the gaelic advice given is good [who knew the celts knew about asbestos?].-nbc
  • Dave in QCA
    Dave in QCA Member Posts: 1,804
    Here is a product
    http://www.fiberlock.com/products/6420.html   This company has some excellent materials.  I have a freind that used this product with excellent results.  I am thinking about using it too.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Jamie Hall Member Posts: 26,183
    Plaster cloth
    wrapped all of mine in plaster cloth -- comes in various widths.  A little messy to put on (!), but when it dries it dries good and hard, and makes a nice neat job.
  • haaljo
    haaljo Member Posts: 112
    "who knew the celts knew about asbestos?].:"
    It was 25 years ago but I took a course on remediation and the instructor mentioned blue a******s as the worst and that it is common in Celtic construction.
    That remains with me today although I have not seen any albeit I try to avoid seeing any colors of the stuff.
