Asbestos
Member Posts: 1
I have asbestos on my steam pipes is there anything that they use to cover the pipes, with out removing the asbestos. Thanks tom
Fabric
Mine were wrapped in a couple of layers of cloth and then the cloth was saturated with paint . . . almost like they are in a plaster cast. Best to let somebody who is properly trained do the job.0 -
re
na bi ag caint0 -
I get it.
;-)Retired and loving it.0 -
I had to google it
I get it now0 -
na bi ag caint
you could get the foil-backed, thin fiberglass insulation from the big-box store, and cover over what you have on the pipes now, secured with foil backed sticky tape. you would have to be well protected clothing-wise, and wear a breathing mask. remember that it is the removal/disposal which needs a special licence etc.
the gaelic advice given is good [who knew the celts knew about asbestos?].-nbc0 -
Here is a product
http://www.fiberlock.com/products/6420.html This company has some excellent materials. I have a freind that used this product with excellent results. I am thinking about using it too.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Plaster cloth
wrapped all of mine in plaster cloth -- comes in various widths. A little messy to put on (!), but when it dries it dries good and hard, and makes a nice neat job.Br. Jamie, osb
"who knew the celts knew about asbestos?].:"
It was 25 years ago but I took a course on remediation and the instructor mentioned blue a******s as the worst and that it is common in Celtic construction.
That remains with me today although I have not seen any albeit I try to avoid seeing any colors of the stuff.0
