How to ID a millivolt system
Jshine
Member Posts: 19
How can I tell if I have a millivolt system? We have a gas furnace that produces steam for heat - no fans - no cooling. Thermostat is a 2 wire Honeywell T87F. One wire is connected to the pressure control unit - the other wire connects to the low water cut off.
John
John
First sign.
Millivolt systems will not have a shut-off switch on the boiler, or a breaker in the panel. The boiler will most likely not have any high voltage connections on it.0 -
Give me the numbers
from the gas valve. If it is a Honeywell powerpile (750 Millivolt) system it will have an s in the numbers say like a VS-820 valve?
Are you the same person with the question about T8775 thermostat?0 -
millivolt question
Thanks -
Yes - I do have a shut off switch on the boiler
Gas valve is VR 8304M 3152 24v 60hz
so - looks like "not" a millivolt system ??
and yes - I have the post up about the T8775A - after that stat failed to work I got out the boiler manual and read a section "electronic thermostats" - "certain types of electronic thermostats may lose their memory or shut down." the manual goes on to say - "with PS-802 probe type low water cut offs, this may occur each time a low water condition is detected". ...goes on to talk about installing a R8222A relay etc.. so even though it doesn't sound like my situation - now I'm getting spooked about trying another brand new T8775 or using any digital stat. So looking at other stats and reading some posts here - I keep coming across posts that say you can't use a certain stat with a millivolt system - power robbing and so on and so on... pretty confusing for me..that's why I posted the millivolt question.0 -
If you still have your old T87F put it
back it was one of the most reliable thermostats Honeywell ever made.0 -
T87F
That exact thought has crossed my mind - The T87F has worked perfectly - maybe I'll just place a hook next to it to hold a good magnifying glass.
Thanks again for all the good info.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
