Inline air bleeder for PEX
bradk
Member Posts: 1
Is anyone aware of an inline air bleeder for PEX? I could also use an ell if necessary but it needs to be PEX. 3/4" "bleeder ells" were common in copper but I can't seem to find any in PEX. Thanks in advance for any help.
Manifold
When it's necessary it is done at a installed bleeder on the pex manifold.0 -
Thank you for the answer, but it doesn't help! I need it for an elevated section of baseboard . . . there is NO manifold in the system and I am unable to isolate the loop of baseboard to pressure/flow purge it. I need the item I've asked for and will make it, adapt it or have it made, if I cannot purchase the item I've described. I have about a foot of PEX to work with where I can install it.0 -
Drain Coupling
A drain coupling (Bleeder up) and 2 ftg x pex adapters sweated together
http://images.orgill.com/200x200/2112944.jpg0 -
Baseboard T
You can also get a brass baseboard T (Looks like an Ell with an 1/8in. threaded port) and sweat two pex adaptors into it.Bob Boan
Two words....
Shark Bite....
http://www.cashacme.com/prod_sharkbite_pushfit.php
The system evidently wasn't properly designed and installed in the first place, because if it were, you wouldn't be attempting a bottom fill, top purge.
Purging is usually done in the mechanical room where there is a floor drain.
ME0 -
ME
Amen to that0
