Inline air bleeder for PEX
bradk
bradk Member Posts: 1
Is anyone aware of an inline air bleeder for PEX? I could also use an ell if necessary but it needs to be PEX. 3/4" "bleeder ells" were common in copper but I can't seem to find any in PEX. Thanks in advance for any help.
  • HDE
    HDE Member Posts: 225
    edited November 2010
    Manifold
    When it's necessary it is done at a installed bleeder on the pex manifold.
  • oldBrad
    oldBrad Member Posts: 1
    Thank you for the answer, but it doesn't help! I need it for an elevated section of baseboard . . . there is NO manifold in the system and I am unable to isolate the loop of baseboard to pressure/flow purge it. I need the item I've asked for and will make it, adapt it or have it made, if I cannot purchase the item I've described. I have about a foot of PEX to work with where I can install it.
  • HDE
    Drain Coupling
    A drain coupling (Bleeder up) and 2 ftg x pex adapters sweated together
    http://images.orgill.com/200x200/2112944.jpg
  • Ironman
    Ironman Member Posts: 7,908
    Baseboard T
    You can also get a brass baseboard T (Looks like an Ell with an 1/8in. threaded port) and sweat two pex adaptors into it.
    Bob Boan
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Two words....
    Shark Bite....
    http://www.cashacme.com/prod_sharkbite_pushfit.php
    The system evidently wasn't properly designed and installed in the first place, because if it were, you wouldn't be attempting a bottom fill, top purge.
    Purging is usually done in the mechanical room where there is a floor drain.
    ME
  • HDE
    ME
    Amen to that
