Indrect Water Heater Pex-al boiler supply line
Is their any reason that I am not thinking of when wanting to use Pex-al to go from boiler to indirect hot water heater.  The heater needs to be put about 30 feet away and copper is getting pricey.  I know it is better to have less distance but homeowner wants it where their old heater was.  Thanks
Also thoughts on stainless steel vs stone-line tanks, in hard water area without water softner
  • Ironman
    Ironman Member Posts: 7,903
    Pex-Al-Pex...
    Is fine on any hydronic line.
    I don't know what the difference would be on the s.s. tank vs. the stone lined, I've used both. Water hardness would effect the coil with scaling in either case.
    Bob Boan
