Reverse Threads on Wall mounted radiator
CB73
I have a two section ornate wall mount radiator that I bought and had sandblasted. One side of the radiator has reverse threads,( by that I mean you turn left to tighten) I assume that is so that sections can be joined with one fitting. Well I cut out the lower reverse threaded plug hoping to buy a 1 1/2 reverse threaded bushing with regular threaded 1/2 for my hot water system. My local plumbing supply store did not have it and did not know where to get it. First, reverse outer and regular inner is what I am looking for correct? And seconds there a place that anyone knows of that would sell something like this, either via an online store, or by calling and having the part shipped?
Re: left hand thread bushing
I have had to have them made by machine shop. Not too painful but the most single expensive pipe fitting you will probably ever buy.
Tim 0 -
Re: left handed bushing
Thanks tim. I thought I might have to go that route, I just wanted an easier way out. I am in for 160 bucks for the radiator, sandblasting, fittings etc, so it WILL be put into service
seen them once
around 1989 in london england on new cast iron rads. left and right close nipples
the company was in southend sorry thats all i can remember0
- 167 Indoor-Air Quality
