Reverse Threads on Wall mounted radiator
CB73
I have a two section ornate wall mount radiator that I bought and had sandblasted. One side of the radiator has reverse threads,( by that I mean you turn left to tighten) I assume that is so that sections can be joined with one fitting. Well I cut out the lower reverse threaded plug hoping to buy a 1 1/2 reverse threaded bushing with regular threaded 1/2 for my hot water system. My local plumbing supply store did not have it and did not know where to get it. First, reverse outer and regular inner is what I am looking for correct? And seconds there a place that anyone knows of that would sell something like this, either via an online store, or by calling and having the part shipped?
Re: left hand thread bushing
I have had to have them made by machine shop. Not too painful but the most single expensive pipe fitting you will probably ever buy.Tim
Re: left handed bushing
Thanks tim. I thought I might have to go that route, I just wanted an easier way out. I am in for 160 bucks for the radiator, sandblasting, fittings etc, so it WILL be put into service0 -
seen them once
around 1989 in london england on new cast iron rads. left and right close nipples
the company was in southend sorry thats all i can remember0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
