Trane XL 80 Blinking red light
Marco_Antonio
in Gas Heating
Lost my owners manual. I have a Trane TUD080R936H furnace that quit heating last night. There is a red blinking light. Anyone know what the problem is?
I assue the blinking light is
on the control (Integrated Furnace Control) in the blower compartment, is that correct?
What is the make and number of that control?0 -
Found the diagnostics on the Integrated Furnace Control and it says the slow blinking red light indicates NORMAL-NO CALL FOR HEAT. Last night I followed the instructions for a restart and it lit the burner tubes (sorry for the rookie terminology) for a few seconds and then quit. So I shut the furnace down per the instructions.
Further investigation leads me to belief that it's the flame sensor.
A few minutes ago I cleaned (vacuumed) the motherboard and bottom section of the furnace, assuming that's the blower compartment, and followed the restart sequence. The furnace restarted and is working as normal right now. If I take the bottom cover off the switch will shut down the system. So I'm going to let the house warm for a while. Wife and all..... Unfortunatly I have to return to work for the day. Should I shut it down tonight and give you the information?
Marco0 -
Let it run if it will
do so normally and get me the numbers of the controls and the make.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
