copper vs black
Is it ok to use copper to relocate steam radiators? or should I only use black pipe
  • Joe V_2
    Joe V_2 Member Posts: 234
    stick with black pipe.
    It will be quieter and last longer with all the expanding and contracting it will do.
  • newsteamguy
    newsteamguy Member Posts: 2
    noise
    will copper make more noise? why would that be?
  • Dave in QCA
    Dave in QCA Member Posts: 1,786
    Properties of copper
    Copper expands more than iron when heated.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Joe V_2
    And
    if it rubs on the penetration hole, you will hear it tick, tick, tick.
    Jamie Hall Member Posts: 23,403
    It may be more...
    than tick tick tick.  It's surprising how loud expansion noises can be!
    But the other problem with the expansion is the stress it places on the joints.  With black iron, all your joints are threaded and they can give a little as the pipe expands and contracts, without leaking.  With copper, they're going to be soldered -- and in time the stresses may result in the joint leaking (although I have to confess that there's one radiator in my building which was repiped in copper about 40 years ago, and hasn't leaked yet, so maybe that's not such a problem?).
  • SteamHeat
    SteamHeat Member Posts: 159
    Is It Okay For The Condensate Return...
    Is copper okay for the condensate return line because the water in the return line has much less heat than the steam from which it condensed ?
  • jpf321
    jpf321 Member Posts: 1,568
    1-pipe Homeowner - Queens, NYC
    NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
    installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
    Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
    my NEW system pics | my OLD system pics
