please help wiring R89 relays to new boiler
John B_2
Member Posts: 46
System has three RA89A relays and the guy wired all three relays with a common red and white lead and then wired that to the T and TV on the boiler.
Now the boiler circ pump constantly runs and so do the zone pumps which are connected to the relays.
the boiler aquastat control is a L8148e
The answer is basic
not wired properly. Go to the wiring diagrams and start fresh.Cost is what you spend , value is what you get.
cell # 413-841-6726
The RA89 relays
are a circulator only relay they do not have an isolated set of switches to be wired to T and TV. You might want to get a Taco 503 which would work great for your situation. It will run the circulators and wire to your aquastat relay for burner and boiler circulator operation.0 -
Tim, thanks but I,ve just bought the Tekmar 401
House control. Thanks for your post.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
