Boiler stainless heat exchanger
Karl_Northwind
Karl_Northwind Member Posts: 139
Hi All, I'm looking for a source of engineering and or source for a stainless heat exchanger similar to what's in the munchkin contender/munchkin/lochnivar knight/NTI, etc.
I'm inquiring for a customer who wants to do some heat recovery from a boiler stack (extremely expensive custom boiler for process heating, so a simple boiler upgrade is out of the question) he'd be mounting it in a stainless housing outside the building, with a condensate drain back in to the building. Not that we expect it to condense often, but it could happen.  they're running 16 gpm of cold water in 10 hours a day, and anything we can get out of it will be good.
of course this would be a custom job, but if we can buy the HX, so much the better.
Thanks
Karl
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Contact
    Giannoni a French maker of stainless steel heat exchangers. A Google will get you to their web site.
  • Karl_Northwind
    solution!
    http://www.cainind.com/cain_cat_boiler_economizer.php
    they have pre-engineered application specific heat recovery systems.  really slick.
    solar is great, (and my primary business) but heat recovery applications make so much more sense in many applications.
    thanks for the Giananni name.  I'd heard it but couldn't recall it.
    Karl
