Boiler stainless heat exchanger
Karl_Northwind
Member Posts: 139
in Gas Heating
Hi All, I'm looking for a source of engineering and or source for a stainless heat exchanger similar to what's in the munchkin contender/munchkin/lochnivar knight/NTI, etc.
I'm inquiring for a customer who wants to do some heat recovery from a boiler stack (extremely expensive custom boiler for process heating, so a simple boiler upgrade is out of the question) he'd be mounting it in a stainless housing outside the building, with a condensate drain back in to the building. Not that we expect it to condense often, but it could happen. they're running 16 gpm of cold water in 10 hours a day, and anything we can get out of it will be good.
of course this would be a custom job, but if we can buy the HX, so much the better.
Karl
Karl
Contact
Giannoni a French maker of stainless steel heat exchangers. A Google will get you to their web site.0 -
solution!
http://www.cainind.com/cain_cat_boiler_economizer.php
they have pre-engineered application specific heat recovery systems. really slick.
solar is great, (and my primary business) but heat recovery applications make so much more sense in many applications.
thanks for the Giananni name. I'd heard it but couldn't recall it.
Karl0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
