indirect performance
jim_160
jim_160 Member Posts: 24
Can you increase the performance of a 41 gallon amtrol indirect heater by increasing the size of pipe or increase circulator or both?
  • Ironman
    Ironman Member Posts: 7,858
    Need more info
    What is the Btu output of your boiler? What size pump (make & model) and piping do you have?
    The answer may be yes if the boiler's full capacity is not being utilized and if increasing the flow rate doesn't exceed 4ft. per second.
    Bob Boan
  • Brad White
    Brad White Member Posts: 2,399
    Flow vs. Temperature
    Flow is not a very effective variable. You can double your flow (and increase your pressure drop by a factor of over three and your pump power by a factor of over eight), yet get less than 10% more capacity.
    The best variable is temperature, increasing the temperature 20 degrees, say from 160 to 180F, and get about 20-25% more heat transfer, in rough terms. (The temperature differences in the process always move/vary; they start out high and diminish as the tank comes up to maximum temperature, which is why this is a qualified answer.) But you get the idea.
    As Ironman said, you need to know your boiler output capacity and your line size vs. flow rate. Having the Amtrol rating tables is also essential.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • tim smith
    tim smith Member Posts: 2,886
    Re: capacity of indirect
    If you find you are lacking hot water, 2 things, increase boiler temp to say 180 to help recovery, 2nd, install thermostatic mix valve on hot out and increase stored temp to say 150 or even 160. This will give you much more stored energy in the hot water tank. Good luck, Tim  Ps, hi Brad
  • billtwocase
    billtwocase Member Posts: 2,384
    careful
    of max water temps on tanks, Warranty will be void trying to increase output by cranking it up and using a mixing valve.
