peerless lc/lce gas gun
clammy
Member Posts: 3,242
in Gas Heating
i am looking at installing a peerless LC/LCE 08 steam boiler and have a choice of which gas gun i can get with it .I know i would like to use one which will give me hi low fire opitions but am unsure of which brand to go with that are rated for use with this boiler a few choices are power flame ,beckett and gordan platt .Does any one one have any negitive experenes with power flame being they are usually the most widely used in gas application and do offer a hi low fire set up and i believe full mod might be avaiable ,also the building is now with out heat apartment set up and also has been severly knuckleheaded and is in need of alot of deknuckleheading and a new boiler ,thanks for any input on the burner side peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Power Flame is a good
application for gas. They also offer a dual fuel application if I am not mistaken. You may want to check with "Steamhead" and some of the others as to some two stage applications they have been using with steam0
