Piping and wiring Qs about the Peerless Purefire
Ron Jr._3
Member Posts: 605
Anyone install these on a regular basis ? Have a few question on how to pipe and wire 2 radiant zones to existing pipework on this specific boiler . Already has an indirect and 3 baseboard zones .
Thanks in advance .
Thanks in advance .
Same
as any other P/S setup. Are both radiant zones going to be the same temp?0 -
Same temp
for both radiant zones .
This was more a wiring question than piping . The internal control has the capacity to run a general pump ( for the boiler ) , a DHW pump and a CH pump ( for the heating zones ) . Since the radiant needs it's own pump , you can't control the CH pump normally anymore and you lose some advanced functions . I guess a RIB relay tied into a single zone relay for the radiant might work . Gotta think about that .......
Does the I series Taco zone valve work downstream of a pump ? Can it work on just water temp ? With a mix valve that can be piped after a circ you could do different temperature zones on one pump, theoretically ..........................0 -
I- valve
You have to pull through it0
- 167 Indoor-Air Quality
