Piping and wiring Qs about the Peerless Purefire
Ron Jr._3
Member Posts: 603
Anyone install these on a regular basis ? Have a few question on how to pipe and wire 2 radiant zones to existing pipework on this specific boiler . Already has an indirect and 3 baseboard zones .
Thanks in advance .
Thanks in advance .
Same
as any other P/S setup. Are both radiant zones going to be the same temp?To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Same temp
for both radiant zones .
This was more a wiring question than piping . The internal control has the capacity to run a general pump ( for the boiler ) , a DHW pump and a CH pump ( for the heating zones ) . Since the radiant needs it's own pump , you can't control the CH pump normally anymore and you lose some advanced functions . I guess a RIB relay tied into a single zone relay for the radiant might work . Gotta think about that .......
Does the I series Taco zone valve work downstream of a pump ? Can it work on just water temp ? With a mix valve that can be piped after a circ you could do different temperature zones on one pump, theoretically ..........................0 -
I- valve
You have to pull through itTo learn more about this professional, click here to visit their ad in Find A Contractor.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 27 Recall Announcements
