STEAM BOILER NO RETURN
WDEANCO
Member Posts: 2
I AM QUOTING A OIL FIRED STEAM BOILER BUT I AM CONCERNED BECAUSE IT DOESN'T HAVE HARTFORD LOOP, EQUALIZER OR RETURN. THE WATER RETURNS THE SAME PIPING THE STEAM GOES UP. THE OLD BOILER IS ONLY 6 YRS OLD AND ROTTED OUT ON THE TOP OF THE SECTIONS, COULD THIS NO RETURN HAVE CAUSED THIS .
That`s a,
counterflow system.
Laosh describes this type & others in detail, if you do not have a copy, I strongly suggest getting-it!
Click on the "shop" tab at the top of this page.0 -
LAOSH
Hi- Follow Dave's advice and get "The Lost Art of Steam Heating" http://www.heatinghelp.com/products/Books/5/68/Lost-Art-Of-Steam-Heating
My copy has easily paid for itself several hundred times over.
I've attached a couple of photos of an excellent counterflow system done by Steve Gronski. Note the dropheader and drip layouts.
The boiler rotting out sounds like a water problem. The boiler water's PH needs to be checked or it might also be that fresh water has been added to the boiler without it being brought to a boil to drive off the excess oxygen.
- Rod0 -
COUNTERFLOW STEAM SYSTEM
THANKS FELLAS, I DO HAVE LOST ART OF STEAM I WILL HAVE TO LOOK CLOSER.0 -
Counterflow System.
Counterflow- Try page 83 TLAOSH. Study the photos. I think Steve Gronsky's approach is superior to the illustration in the book as for one, there would be less conflict between the steam stream and the returning condensate - Rod0 -
Rod,
I agree that Steve did a great job piping your steam boiler, but I see no drop header in the conventional sense in the pics. ;-)0 -
Regular Header
Dave- You have a good eye! You right! It has a regular header and equalizer. I guess my brain was concentrating on finding a photo of a good counterflow drip system and skipped over the header. BTW this isn't my system. The photo is from a collection I saved of what I call "steam masterpieces". When I see a photo with an exceptionally good approach /configuration, I save it. Now I just have to figure how to get my wife to allow me to frame them and hang them on the den wall!
- Rod0 -
Framed Boiler Photos...
will probably end up hanging on your boiler room wall! This actually presents a good idea! Clean up the boiler room, nice coat of white paint, neat installation, tools put away. Nice cozy warm spot in the winter, maybe an old recliner covered with a blanket, a TV or small sterio, a little fridge for beverages, and pictures of steam masterpieces!
I know that I would enjoy it, and it gives me great ideas for my boiler room!Dave in Quad Cities, America
http://grandviewdavenport.com0
- 120 Geothermal
