Experience with Vent Rete steam vents?
I am looking for very low capacity radiator and convector vents for balancing.  So far I have used Hoffman 1A's , however the convector vents are physically huge and 1/4 tapping.  The ventrites also are very low capacity and I wanted to try these, but I do not know about the quality.  I hope to use these convector style vents with TRV'S from Danfoss or Tunstall.
Thanks All!!!
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    They are my vent of choice
    they are popular around here and I have had good luck with them. Nothing touches the Gortons for mainline but even there on small systems the vent rites work well.
    cell # 413-841-6726
    Steamhead Member Posts: 18,193
    The Vent-Rite #1
    is my favorite adjustable vent for locations where the occupants want some control over how warm their rooms get. No other vent is so easy to adjust.
    For real low capacity you can't beat the Gorton #4. Besides the usual 1/8" angle configuration, you can also get it in 1/8" and 1/4" straight patterns.
    Consulting
  • Took a look...
    at the vent rites, but they don't make a vertical adjustable....any other suggestions other than the monster Hoffman 1B.  Maybe I'll just need to install a nipple and elbow to use the Radiator vents on a convector.
    two 45's would be better
    two street 45s would also be good. you could use TRVs they have a kit that adapts them to convectors. This has a couple 45's in it.
    cell # 413-841-6726
