Experience with Vent Rete steam vents?
The Steam Whisperer (Formerly Boilerpro)
Member Posts: 834
I am looking for very low capacity radiator and convector vents for balancing. So far I have used Hoffman 1A's , however the convector vents are physically huge and 1/4 tapping. The ventrites also are very low capacity and I wanted to try these, but I do not know about the quality. I hope to use these convector style vents with TRV'S from Danfoss or Tunstall.
Thanks All!!!
Thanks All!!!
They are my vent of choice
they are popular around here and I have had good luck with them. Nothing touches the Gortons for mainline but even there on small systems the vent rites work well.Cost is what you spend , value is what you get.
cell # 413-841-6726
The Vent-Rite #1
is my favorite adjustable vent for locations where the occupants want some control over how warm their rooms get. No other vent is so easy to adjust.
For real low capacity you can't beat the Gorton #4. Besides the usual 1/8" angle configuration, you can also get it in 1/8" and 1/4" straight patterns.All Steamed Up, Inc.
Consulting0 -
Took a look...
at the vent rites, but they don't make a vertical adjustable....any other suggestions other than the monster Hoffman 1B. Maybe I'll just need to install a nipple and elbow to use the Radiator vents on a convector.There was an error rendering this rich post.
two 45's would be better
two street 45s would also be good. you could use TRVs they have a kit that adapts them to convectors. This has a couple 45's in it.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
