service
RichG_Beverly2
Member Posts: 1
I went to the Reznor web site looking for wiring diagrams for Mod # RPBL600-8-S-MU controlled from a Selectra Maxitrol controller. After two attempts I received error messages. Does anyone know where I may find this info? Also, this was the first time that I looked at this MAU and at some point the cooling was disconnected from the Maxitrol. The two stage cond unit was being controlled from a two stage Ranco electronic temperature controller located in the blower compartment. I wonder what happens in the heating mode. I assume that the Maxitrol is defective.
Try the Reznor site again
as I was able to reach a PDF file on the RPB series with no problem at all.
[url=http://www.rezspec.com/index.php?pageid=0000000000148mod_files[currpos]=000000000002]www.rezspec.com/index.php?pageid=0000000000148mod_files[currpos]=0000000000020
