condenser, air to water
NRT_Rob
Member Posts: 1,013
is it possible to convert an air to air condenser unit to an air to water unit with a suitable brazed plate heat exchanger on the refrigerant line?
has anyone done this?
Rob Brown
in beautiful Rockport Maine.
Condenser
Yes, just use a standard water cooled condenser. Could be shell and coil, tube-in-tube, or plate.0 -
thanks tom
other than proper sizing, of course, any problems with this?
I imagine it would be even better than normal, since water offers "buffer capacity" air can't. but I'm making that up.Rob Brown
Lift
The only problem that might be encountered would be a lack of subcooling, resulting in flashing in the liquid line if there is a substantial rise in elevation where the evaporator is located higher than the condenser. As long as the liquid lift is less than 15 feet or so should be ok.0
- 123 Chimneys & Flues
