condenser, air to water
NRT_Rob
Member Posts: 1,013
is it possible to convert an air to air condenser unit to an air to water unit with a suitable brazed plate heat exchanger on the refrigerant line?
has anyone done this?
Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.
Condenser
Yes, just use a standard water cooled condenser. Could be shell and coil, tube-in-tube, or plate.0 -
thanks tom
other than proper sizing, of course, any problems with this?
I imagine it would be even better than normal, since water offers "buffer capacity" air can't. but I'm making that up.Rob Brown
in beautiful Rockport Maine.0 -
Lift
The only problem that might be encountered would be a lack of subcooling, resulting in flashing in the liquid line if there is a substantial rise in elevation where the evaporator is located higher than the condenser. As long as the liquid lift is less than 15 feet or so should be ok.0
