What brand Manometer is best?
michael_34
Member Posts: 304
What is a good digital manometer for reading gas flow (Water Column) and what kind of price should I expect?
Thanks
Michael
Thanks
Michael
Wohler & Testo
both make good ones which I use at my training center. However for just measuring gas pressure I recommend an actual plastic "U" tube type as it is much less expensive and you do not have to worry about dropping it.
If however you are looking to use a manometer for testing pressure switches etc. then the digital is the answer.
Sorry I do not have prices for you but check with your local heating supply company.0
- 120 Geothermal
