What brand Manometer is best?
michael_34
michael_34 Member Posts: 304
What is a good digital manometer for reading gas flow (Water Column) and what kind of price should I expect?
Michael
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Wohler & Testo
    both make good ones which I use at my training center. However for just measuring gas pressure I recommend an actual plastic "U" tube type as it is much less expensive and you do not have to worry about dropping it.
    If however you are looking to use a manometer for testing pressure switches etc. then the digital is the answer.
    Sorry I do not have prices for you but check with your local heating supply company.
