Removing 40 yr Old solar tank
Solarstar
Solarstar Member Posts: 81
Was cutting it apart to get the weight down (400 pounds) and was totally amazed at the internal condition of the tank. Very minor scale /buildup  . the internal lower copper heat transfer coil was almost  new with very minor scale as well. the Electric element was never wired up.    Paul
Forgot to say its a Ford Stone lined tank...
  • Kevin_in_Denver_2
    Kevin_in_Denver_2 Member Posts: 588
    Why did you remove it?
    Was it leaking?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,425
    time for a
    electric hand truck.
    cell # 413-841-6726
    hot_rod Member Posts: 27,333
    how did you cut it?
    with that stone lining inside
  • Solarstar
    Re tank cutting
    Hi  HR: I cutting it into 2 foot sections with a thin kerf 5" grinder wheel , to my surprise the actual metal is quite thin ,then a couple hits with a sledge and it breaks cleanly on the cut line thru the 5/8 inch layer of Concrete.   Paul
  • Solarstar
    edited April 2010
    Re : why tank removal
    Hi Kevin : Yes the  internal coil had developed a pinhole leak of some sort ,but no external tank leaks at all .In the day these were one of the best tanks out there . Now running my Evacs into a 120 gal dual coil ss tank and a Smart 40 I'm working for overflow (temp). All pumped by a single 20 watt  PV  DC pump which provides nice linear /proportional control..... with 8 people in the house we use lots of water.   Paul
