Removing 40 yr Old solar tank
Was cutting it apart to get the weight down (400 pounds) and was totally amazed at the internal condition of the tank. Very minor scale /buildup . the internal lower copper heat transfer coil was almost new with very minor scale as well. the Electric element was never wired up. Paul
Forgot to say its a Ford Stone lined tank...
Why did you remove it?
Was it leaking?There was an error rendering this rich post.
time for a
electric hand truck.Cost is what you spend , value is what you get.
cell # 413-841-6726
how did you cut it?
with that stone lining insideBob "hot rod" Rohr
Living the hydronic dream0 -
Re tank cutting
Hi HR: I cutting it into 2 foot sections with a thin kerf 5" grinder wheel , to my surprise the actual metal is quite thin ,then a couple hits with a sledge and it breaks cleanly on the cut line thru the 5/8 inch layer of Concrete. Paul0 -
Re : why tank removal
Hi Kevin : Yes the internal coil had developed a pinhole leak of some sort ,but no external tank leaks at all .In the day these were one of the best tanks out there . Now running my Evacs into a 120 gal dual coil ss tank and a Smart 40 I'm working for overflow (temp). All pumped by a single 20 watt PV DC pump which provides nice linear /proportional control..... with 8 people in the house we use lots of water. Paul0
- 87.8K THE MAIN WALL
