endurance domestic hot water problem
webskier
Member Posts: 8
I have an issue with lack of dom. hot water when space heat is on
DHW problems
Could be a few things, flow switch, anti condensing valve, clogged heat exchanger or bad mixing valve. If you're a tech, bust out the volt/ohm meter and temperature takin' devices. If you're a homeowner, bust out the yellow pages or click Find a Professional at the top of this page.0 -
How long has this
been going on? The reason I ask is it sounds like the parameters on your system may not be set up to give domestic priority. I would call your installer or local Triangle Tube service company.
Did anyone touch any of the buttons on your unit?0 -
It's a Laars product
Hey Tim,
He mentioned it's an Endurance which is a Laars product, The Endurance was developed by Laars and was so similar to the Trianco Heatmaker, that Laars brought out Trianco to avoid patent and copyright issues. At least that's what I've heard0 -
Sorry about that I was thinking
of the TT Excellence my mistake.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
