endurance domestic hot water problem
webskier
webskier Member Posts: 8
I have an issue with lack of dom. hot water when space heat is on
  • Slimpickins
    Slimpickins Member Posts: 360
    DHW problems
    Could be a few things, flow switch, anti condensing valve, clogged heat exchanger or bad mixing valve. If you're a tech, bust out the volt/ohm meter and temperature takin' devices. If you're a homeowner, bust out the yellow pages or click Find a Professional at the top of this page.
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    How long has this
    been going on? The reason I ask is it sounds like the parameters on your system may not be set up to give domestic priority. I would call your installer or local Triangle Tube service company.
    Did anyone touch any of the buttons on your unit?
  • Slimpickins
    It's a Laars product
    Hey Tim,
    He mentioned it's an Endurance which is a Laars product,  The Endurance was developed by Laars and was so similar to the Trianco Heatmaker, that Laars brought out Trianco to avoid patent and copyright issues. At least that's what I've heard
  • Tim McElwain
    Sorry about that I was thinking
    of the TT Excellence my mistake.
