If our community has helped you, please consider making a contribution to support this website.  Thanks!
Leak Loc
                    Techman
                    Member Posts: 2,143
                    I have been using LeakLoc thread sealant for years and just recently my electronic leak detector activated when leak testing a fitting that I had used LeakLoc on.Then I tested the LeakLoc container and my electronic went crazy.Did this happen to anyone else?
            yes
My leak detector has been doing that for a while, don't know what is in it to cause this but many times while leak checking i forget grab the bubbles trying to pinpoint the leak then i remember that leak loc sets it off. have to look into the reason why tim0 -
            Of course it does!
LeakLoc contains Ethanol (Ethyl Alcohol) which is sensed by many electronic leak detectors.0 -
            of course
a horse is a horse,OF COURSE ,OF COURSE.Thanks!0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
