Is Weil McClain a good boiler
Hey_Obie
Member Posts: 66
I am looking to replace my 30 year old HB Smith oil boiler. I really like the tankless water heater that is in the current unit. I find it hard to justify the price of indirect water heaters so I'd like to stay with a tankless heater in the boiler. I am looking at the Weil McClain WTGO-3 (115 100 .95).
Has anyone had problems with the Weil McClain? Any comments or suggestions appreciated.
Thanks,
Obie
Thanks,
Obie
Boiler
Well it's a basic boiler with O-ring construction rather then push nipples ... O-rings can leak ...Seen a few after 20 years.... That model has been around for a long time ...There was an error rendering this rich post.
Tankless
you can not see the expense of a Hot water maker A tank less runs all the time as it says "SUMMER /WINTER". You never have enough hot water , flashing from hot to cold . Not to mention the temperatures that you need to run. Can't have reset .In the long run you have to save money0 -
good boiler
I prefer the Carlin EZ-1 on these. Switched to them a few years back, so far so good. That was the first boiler here that was coming with the Hydrostat low water cut off/aquastat . Made for a nice package0 -
Haven't had any issues
I haven't come across a bad GO3 yet. We actually install a good amount of these boilers but we use the unit from JOMAR. They use the GO3 with there nameplate and because of that it is slightly discounted.0 -
In my humble (?) opinion...
WM makes good boilers -- but so do several other folks. Keep in mind that what you are really buying is the expertise of the installer; a great installer can do a great job with any one of several brands, but particularly one(s) he or she likes and knows best. On the other hand, a poor installer can mess up any boiler beyond belief, if not beyond recovery.Br. Jamie, osb
We use the special 3L Weil Mclain
in these Levitt homes . 4 foot off the ground right in the kitchen .
Out of the 3 or 4 different pin style boilers we use , the Weil has the lowest stack temp, which should translate to saving fuel . I'd rather see steel or cast iron push nipples holding the sections together , rather than the Neoprene rings . Very rarely do we see a leak on these boilers but when we do it's always at these seals . Like I said though ........ very rare . But we do take out quite a few of the 68 series ( the previous version of the Gold ) , 20 to 30 years old , usually leaking at the gaskets .
Overall , a solidly built boiler .0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
