condensate neutralizers...
kcopp
kcopp Member Posts: 4,435
I had an inspection for a boiler job today... I installed a Embassy Onex 93% afue. it obviously condenses... I seeing here for may years make an acid neutralizer out of PVC TY's and limestone and run it down to the sewer... Inspector does not accept it on the basis I am not certified to "make " such a unit.... unless I have a 3rd party certification... Seems picayune to me... any thoughts?
  • HDE_2
    HDE_2 Member Posts: 140
    Worked for me
    Make up a neat little label with a part number, address and a brand name and they never can tell it's homemade anymore.
  • TonyS
    TonyS Member Posts: 849
    Actually it illegal for you
    to dump unmetered water down a sewer. After UL decides it needs a piece of the action, your case will be the norm, then the money hungry sewer and water authorities will get on the band wagon and require a meter on the waste so your customer can be charged. If possible dump your waste outside in a rain conductor or a small pit in the yard and avoid the whole mess.
  • kcopp
    really... the plot
    thickens... I am about ready to drill a hole in the basement floor and dump it there. I know for a fact that there is nothing but sand under the basement slab. I guess I can buy one of the units advertised here on the side of the post... Just seems strange about needing to be certified after a number of years  A LOT of well respected people on the wall  say to DIY w/ these units....:(
  • Jack
    Jack Member Posts: 1,047
    Careful
    If you go under the slab, the condensate will be perfectly happy to eat your slab from the bottom up.
  • TonyS
    The one advertised on the sidebar
    is not third party tested. They are no more qualified than you to put some calcite in a tube.
  • Tim McElwain
    Tim McElwain Member Posts: 4,626
    Why not spend
    a couple of thousand dollars for third party testing and start our own company making neutralizers. Say I think Viessmann may have one for $300 just not sure if it has been third party tested.
    Maybe all the boiler and furnace manufacturers have some responsibility here as to actually having the neutralizer a part of the package with approval a part of the package.
  • kcopp
    well hopefully...
    my "non approved " condensate treatment would fix that issue.
  • Big Ed_4
    Big Ed_4 Member Posts: 2,795
    Peerless
    Peerless incorporates an second trap where you pour a tiny bag of lime stone into it... Me I make up a 4" tube where I can pour 20 # into it and then make sure the condensate filters up from the bottom... How much is enough and do we ever need to change the lime stone ???
  • Big Ed_4
    Peerless
  • Paul Rohrs_14
    Paul Rohrs_14 Member Posts: 80
    degrees of separation
    Wow, hard to believe an inspector has the prowess to deadline something necessary like that.
    There are (literally) only a few degrees of separation from being "hydronic-heated" to "hydroni-cheated".
    Good on ya mate for doing what you know to be right.
    Paul
