What brands of hot water heaters would you recommend?
Radiohead
Member Posts: 8
in Gas Heating
My plumber is replacing my boiler with a Viessmann, he is recommending a Triangle Tube or Lochinvar hot water heater.. Will those work well with the Viessmann?
Which Viessmann
is he installing? Why not go with the Viessmann indirect?0 -
You dont need a Hot water heater!
since there is little reason to heat hot water. What you need is a cold water heater! Sorry I couldnt resist that.LOL0
- 167 Indoor-Air Quality
