What brands of hot water heaters would you recommend?
Radiohead
Member Posts: 8
in Gas Heating
My plumber is replacing my boiler with a Viessmann, he is recommending a Triangle Tube or Lochinvar hot water heater.. Will those work well with the Viessmann?
Which Viessmann
is he installing? Why not go with the Viessmann indirect?0 -
You dont need a Hot water heater!
since there is little reason to heat hot water. What you need is a cold water heater! Sorry I couldnt resist that.LOL0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
