New valves for an old vapor system..
tmw
tmw Member Posts: 56
I've got an Arco Model K vapor orifice system and am looking for some new valves. Does anyone produce a thermostatic valve with an adjustable orifice?
  • Thermostatic Orifice Valves
    Hi - Try Tunstall. They make Macon TRVs.   http://www.maconcontrol.com/inletorifice.html
    - Rod
    Steamhead Member Posts: 16,845
    Not that I know of
    you'd need to add an orifice plate. But a TRV already has some resistance built in, so you may not need to add any.
    Consulting
  • tmw
    much thanks for the replies...
    and Steamhead, what say you about rebuilding the original valves?
    Still working on that
    I got back and hit the ground running, a lot of systems developed problems over that first cold weekend. We're almost caught up, just in time for the next one. 24 inches of snow so far.......
    Consulting
  • Adjustable orifice Valves..
    Check out "Mepco" and "Barnes and Jones".  Mepco lists one and B and J aldo has something, I think.
    Boilerpro
  • Steve_210
    Steve_210 Member Posts: 646
    Model K vapor system
    we just added 250 orifice plates to a system. 150 were trv;s 100 regular and the rest are original model k. while it got rid of the water hammer some of the original rads now heat better than the new. i wish the new orifaces were adjustable.
  • Adjustable Orifice Valves
    I think these are the ones that Boiler Pro was mentioning.
  • tmw
    thanks for all the replies..
    I've seen several brands of adjustable orificie valves. Is it possible to add individual thermostatic regulation to them?
  • Wellll......
    You could purchase the Mepco valves and then have Tunstall build TRV inserts for them.  They do custom work.
    Boilerpro
