New valves for an old vapor system..
tmw
Member Posts: 56
I've got an Arco Model K vapor orifice system and am looking for some new valves. Does anyone produce a thermostatic valve with an adjustable orifice?
Thermostatic Orifice Valves
Hi - Try Tunstall. They make Macon TRVs. http://www.maconcontrol.com/inletorifice.html
- Rod0 -
Not that I know of
you'd need to add an orifice plate. But a TRV already has some resistance built in, so you may not need to add any.All Steamed Up, Inc.
Consulting0 -
much thanks for the replies...
and Steamhead, what say you about rebuilding the original valves?0 -
Still working on that
I got back and hit the ground running, a lot of systems developed problems over that first cold weekend. We're almost caught up, just in time for the next one. 24 inches of snow so far.......All Steamed Up, Inc.
Consulting0 -
Adjustable orifice Valves..
Check out "Mepco" and "Barnes and Jones". Mepco lists one and B and J aldo has something, I think.
BoilerproThere was an error rendering this rich post.
Model K vapor system
we just added 250 orifice plates to a system. 150 were trv;s 100 regular and the rest are original model k. while it got rid of the water hammer some of the original rads now heat better than the new. i wish the new orifaces were adjustable.0 -
Adjustable Orifice Valves
I think these are the ones that Boiler Pro was mentioning.0 -
thanks for all the replies..
I've seen several brands of adjustable orificie valves. Is it possible to add individual thermostatic regulation to them?0 -
Wellll......
You could purchase the Mepco valves and then have Tunstall build TRV inserts for them. They do custom work.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
