Insulating
REX
REX Member Posts: 29
If you cant use black pipe and cast iron emitters,you should insulate all copper heating pipes,thats how i was taught. What do u think about insulating all heating pipes?
  • Al Letellier_21
    Al Letellier_21 Member Posts: 400
    insulating piping
    In my book, all heat piping should be insulated.The pipe is just the conduit to get the BTUs to where you want them. Uninsulated pipe = lost energy.
    Jamie Hall Member Posts: 26,837
    Doesn't matter
    what the metal is -- copper or black or whatever.  If it's not intended as an emitter or radiator and it's a steam or hot water line, insulate it.  If it's a dry return or wet return, it doesn't matter so much -- but if it's a hot water system, I'd insulate everything that wasn't an emitter.
  • REX
    indeed
    thats how you do it
