Battery backup
gmusser
Member Posts: 5
in Gas Heating
We have an inordinate number of blackouts in our area, so I'd like to install a battery backup for our gas boiler for our single-pipe steam system. The required capacity should be fairly low, since power is required just for control purposes. Does anyone have any recommendations?
George Musser
George Musser
Convert it to
a Powerpile Self Generating system and it will run without power.0 -
You could
use a deep cycle battery and an inverter. But I can't recommend that because it probably violates code, and takes human intervention.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
