got enclosures??
jpf321
Member Posts: 1,568
<span>I'm just posting this as an FYI ... 46 pages of 1927 Enclosure Research done at univ of Illinois .. <a href="http://www.ideals.illinois.edu/bitstream/handle/2142/4515/engineeringexperv00000i00169.pdf?sequence=3">http://www.ideals.illinois.edu/bitstream/handle/2142/4515/engineeringexperv00000i00169.pdf?sequence=3</a> nothing earth shattering in the study .. some enclosures which they tested yielded BETTER than non-enclosed rad. </span>
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
That occurred
when they were able to make the enclosure high enough to create a chimney effect. For the usual type of enclosure, they say "it is evident that any enclosure, unless extended to a considerable height above the top of the radiator, will reduce the condensation that would normally be expected from the bare radiator.
In other words, it reduces the radiator's output.All Steamed Up, Inc.
Consulting0
