got enclosures??
jpf321
jpf321 Member Posts: 1,568
<span>I'm just posting this as an FYI ... 46 pages of 1927 Enclosure Research done at univ of Illinois .. <a href="http://www.ideals.illinois.edu/bitstream/handle/2142/4515/engineeringexperv00000i00169.pdf?sequence=3">http://www.ideals.illinois.edu/bitstream/handle/2142/4515/engineeringexperv00000i00169.pdf?sequence=3</a> nothing earth shattering in the study .. some enclosures which they tested yielded BETTER than non-enclosed rad. </span>
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
    Steamhead Member Posts: 18,197
    That occurred
    when they were able to make the enclosure high enough to create a chimney effect. For the usual type of enclosure, they say "it is evident that any enclosure, unless extended to a considerable height above the top of the radiator, will reduce the condensation that would normally be expected from the bare radiator.
    In other words, it reduces the radiator's output.
    Consulting
