chemicals in the boiler room...
Timco
Member Posts: 3,040
Can anyone suggest some reading material regarding the storage of chlorine and other spa related chemicals in a boiler room and it's affects on copper piping and solder joints? I just fixed some pin hole leaks in solder joints and there were several in various places on piping that was not too old. Also, there was huge mineral deposits forming on these leaks, and all the spa & pool chlorine was stored in this room...Thanks!
Tim
Tim
Just a guy running some pipes.
EPA- "Safe Storage and Handling of Swimming Pool Chemicals"
Hi Tim- This might be what you what you are looking for
- Rod
http://www.epa.gov/oem/docs/chem/spalert.pdf
This is from Page 2 -paragraph just before " Improper Mixing"
" Chlorine is corrosive to metals such as steel and copper. Instances have been reported where exposed water piping has become corroded causing leaks, and also where metal storage shelves have corroded and collapsed, leading to chemical spillage"
-0 -
I might add
that some pool chemicals containing chlorine, while not themselves flammable, accelerate combustion and release chlorine gas in the process -- which is highly toxic.
Not good to store in the same room with combustion devices -- like boilers.Br. Jamie, osb
From Lochinvar Knight manual
Products to avoid:
Spray cans containing chloro/fluorocarbons
Permanent wave solutions
Chlorinated waxes/cleaners
Chlorine-based swimming pool chemicals
Calcium chloride used for thawing
Sodium chloride used for water softening
Refrigerant leaks
Paint or varnish removers
Hydrochloric acid/muriatic acid
Cements and glues
Antistatic fabric softeners used in clothes dryers
Chlorine-type bleaches, detergents, and cleaning solvents
found in household laundry rooms
Adhesives used to fasten building products and other
similar products
Areas likely to have contaminants
Dry cleaning/laundry areas and establishments
Swimming pools
Metal fabrication plants
Beauty shops
Refrigeration repair shops
Photo processing plants
Auto body shops
Plastic manufacturing plants
Furniture refinishing areas and establishments
New building construction
Remodeling areas
Garages with workshops
HTH
ME0 -
Acid?
IF the boiler is pulling it's intake air from that room, it's probably doomed.
If you are sucking up chlorine into a boiler intake, when mixed with the products of combustion, it can form hydrochloric acid. It won't be long before a heat exchanger failure presented itself.
Also, there is a reason why we don't use copper heat exchangers (e.g. Brazed plate) for chlorine pools.There was an error rendering this rich post.
- 119 Chimneys & Flues
- 76 Pipe Deterioration
