chemicals in the boiler room...
Timco
Timco Member Posts: 3,040
Can anyone suggest some reading material regarding the storage of chlorine and other spa related chemicals in a boiler room and it's affects on copper piping and solder joints? I just fixed some pin hole leaks in solder joints and there were several in various places on piping that was not too old. Also, there was huge mineral deposits forming on these leaks, and all the spa & pool chlorine was stored in this room...Thanks!
Tim
  • EPA- "Safe Storage and Handling of Swimming Pool Chemicals"
    Hi Tim- This might be what you what you are looking for
    - Rod
     http://www.epa.gov/oem/docs/chem/spalert.pdf
    This is from Page 2  -paragraph just before " Improper Mixing"
    " Chlorine is corrosive to metals such as steel and copper. Instances have been reported where exposed water piping has become corroded causing leaks, and also where metal storage shelves have corroded and collapsed, leading to chemical spillage"
    Jamie Hall Member Posts: 26,842
    I might add
    that some pool chemicals containing chlorine, while not themselves flammable, accelerate combustion and release chlorine gas in the process -- which is highly toxic.
    Not good to store in the same room with combustion devices -- like boilers.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    From Lochinvar Knight manual
    Products to avoid:
    Spray cans containing chloro/fluorocarbons
    Permanent wave solutions
    Chlorinated waxes/cleaners
    Chlorine-based swimming pool chemicals
    Calcium chloride used for thawing
    Sodium chloride used for water softening
    Refrigerant leaks
    Paint or varnish removers
    Hydrochloric acid/muriatic acid
    Cements and glues
    Antistatic fabric softeners used in clothes dryers
    Chlorine-type bleaches, detergents, and cleaning solvents
    found in household laundry rooms
    Adhesives used to fasten building products and other
    similar products
    Areas likely to have contaminants
    Dry cleaning/laundry areas and establishments
    Swimming pools
    Metal fabrication plants
    Beauty shops
    Refrigeration repair shops
    Photo processing plants
    Auto body shops
    Plastic manufacturing plants
    Furniture refinishing areas and establishments
    New building construction
    Remodeling areas
    Garages with workshops
    HTH
    ME
  • SpeyFitter
    SpeyFitter Member Posts: 422
    Acid?
    IF the boiler is pulling it's intake air from that room, it's probably doomed.
    If you are sucking up chlorine into a boiler intake, when mixed with the products of combustion, it can form hydrochloric acid. It won't be long before a heat exchanger failure presented itself.
    Also, there is a reason why we don't use copper heat exchangers (e.g. Brazed plate) for chlorine pools.
