Steam Pressure
dave_20
Member Posts: 5
I know this is Steam 101 stuff but we don't see much of it around here so I don't get much practice - what should the pressure gauge read on a residential Pennco steam boiler? I had one today that was at zero while running.
Sounds about right...
particularly if you are looking at the code 0-30 psi gauge. Most residential steam systems should run less than 2 psi max. -- in fact, most seem to work best in the ounce per square inch range; possibly as high as 1.5 psi cutout/.5 psi cutin. And you won't see that on the code gauge...Br. Jamie, osb
low pressure gauge
you can get a good 0-3 psi low pressure gauge from gaugestore.com and mount it on the same pigtail as the pressuretrol, or better yet vaporstat. that way you know what the pressure is.--nbc0 -
Thanks guys, and..
..I've seen them show a vacuum. Why?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
