Buderus Igniter
The attached picture is of an Ignitor from a Buderus GB142-24 boiler.  The Buderus part number is 7099006.  The label on the wires is Norton Model 601 and was replaced by Buderus with a Norton 601SS.  It operates at 120 volts, has a removable perforated heat shield that terminates as a male grounding terminal.  With the heat shield removed, overall length is about 2 15/32 inches, diameter of the round ceramic base is about 7/8 of an inch.  We'd like to have a spare, but hate to order another from Germany for $125.00 as they are made by Norton in the USA!  Any suggestions where to source one?  Fred Clarke, Lakewood, Colorado. <img />
<a href="javascript:;">[color=#0066cc]PA210047.JPG[/color] [list][li][/li][/list]</a>
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Find out if your local heating supply
    house has Robertshaw controls, those igniters are distributed by Robertshaw. Try FW Webb, Johstone Supply, RE Michel etc.
