Buderus Igniter
FB
Member Posts: 47
The attached picture is of an Ignitor from a Buderus GB142-24 boiler. The Buderus part number is 7099006. The label on the wires is Norton Model 601 and was replaced by Buderus with a Norton 601SS. It operates at 120 volts, has a removable perforated heat shield that terminates as a male grounding terminal. With the heat shield removed, overall length is about 2 15/32 inches, diameter of the round ceramic base is about 7/8 of an inch. We'd like to have a spare, but hate to order another from Germany for $125.00 as they are made by Norton in the USA! Any suggestions where to source one? Fred Clarke, Lakewood, Colorado. <img />
<a href="javascript:;">[color=#0066cc]PA210047.JPG[/color] [list][li][/li][/list]</a>
Find out if your local heating supply
house has Robertshaw controls, those igniters are distributed by Robertshaw. Try FW Webb, Johstone Supply, RE Michel etc.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
