Mixing counter flow and parallel flow
JohnMC
Member Posts: 2
Have a boiler replacement job. Adding new drop header etc. Gave quote, got job found one of two mains is counter-flow. Other main is parallel flow.
Can these two mains work in harmony?
sized and pitched
correctly, don't see why not.Br. Jamie, osb
Counterflow System
Here a picture I saved from last year of a excellent counterflow job done by Steve Gronski. Note the drip setup on the counterflow mains and the 45 degree entry to the header! Beautiful work! I thought maybe it might be of help to you in planning your job.
- Rod0 -
Nice idea
Thanks for the idea, If I use a drip tee and drip leg back to the wet return of the other main, I should still be able to use the drop header I planned on and not have to drop into the counter flow main from the header.
Jamie, thank you as well
If anyone else has any thoughts, I would love to hear them0 -
I'll second Rod and Jamie
that's how I'd do it.All Steamed Up, Inc.
Consulting0
