Mixing counter flow and parallel flow
JohnMC
JohnMC Member Posts: 2
Have a boiler replacement job. Adding new drop header etc. Gave quote, got job found one of two mains is counter-flow. Other main is parallel flow.
Can these two mains work in harmony?
Welcome
It looks like you're new here. Sign in or register to get started.
    Jamie Hall Member Posts: 26,005
    sized and pitched
    correctly, don't see why not.
  • Unknown
    edited October 2009
    Counterflow System
    Here a picture I saved from last year of a excellent counterflow job done by Steve Gronski. Note the drip setup on the counterflow mains and the 45 degree entry to the header!  Beautiful work!  I thought maybe  it might be of help to you in planning your job.
    - Rod
  • JohnMC
    Nice idea
    Thanks for the idea, If I use a drip tee and drip leg back to the wet return of the other main, I should still be able to use the drop header I planned on and not have to drop into the counter flow main from the header.
    Jamie, thank you as well
    If anyone else has any thoughts, I would love to hear them
    Steamhead Member Posts: 17,787
    I'll second Rod and Jamie
    that's how I'd do it.
    Consulting
Welcome
