Insulating floor of a 3-season porch
Nelson_4
Nelson_4 Member Posts: 38
Hi,
I live in Boston and have an unheated 3-season porch. It has been transformed into a daytime playroom and I would like to use it year round. It is 14' x 7', about 100 sq. ft. and I plan to supplement with a space heater.
It is south-facing with a lot of single pane windows. I have already made interior storm windows <a href="http://www.arttec.net/Thermal-Windows/index.html">[url=http://www.arttec.net/Thermal-Windows/index.html]http://www.arttec.net/Thermal-Windows/index.html</a> that made quite a difference. But the floor is still cold.
The floor is carpet on top of plywood. It looks like there is a layer of poly under the plywood. The porch is 3 feet off the ground but is enclosed with thin wood and plaster. I can access the area beneath the porch floor from a door in the basement.  There is no insulation between the floor joists.
My question is, should I insulate under the floor or is it a waste of money? If so, what kind of insulation should I use? (Rigid board, fiberglass, etc.) Would I need to get a building permit?
  • johnnyge
    johnnyge Member Posts: 86
    foam insulation
    I put spray foam insulation to and extension of my living room where the access to the floor was from a crawl space. I think is better that the rigid foam board .Find a company in your area that does foam isulation and get an estimate for the job.
    Jamie Hall Member Posts: 26,828
    Foamed in place
    insulation is definetly the way to go on that one.  I have used a product called Icynene, and it worked very very well.  Try Healthy Home, Inc., in Melrose.
  • Nelson_4
    Open-cell vs. closed-cell
    Thanks for the replies. I got an estimate from Healthy Home over the phone. But the more I looked into spray foam insulation, I am more convinced that my application is better suited for a closed-cell foam, as opposed to open-cell (such as Icynene). Any thoughts on this are appreciated.
    Only comment I'd have
    is that Icynene, though an open cell type foam, is air and moisture impermeable -- and seals uncommonly tightly.  Which is part of what you want.
  • johnnyge
    foam
    The foam insulation will expand and cover every crack you room may have . When i did it on my house, the foam came up to few tiny holes on the top of the hardwood floor, meaning that it will really be a tight sealer for heat loss.
  • kcopp
    kcopp Member Posts: 4,628
    you are right...
    about the closed cell. The urethane (closed cell) is a much better fit. More r value to the inch, better resistance to moisture, better strength per square inch.... many Icene contractors are now going to the closed cell
  • jb_14
    jb_14 Member Posts: 13
    Closed Cell polyruethane foam is the way to go.
    Have used RHH Foam Systems - Versi Foam - done it with my crew.  You can do it or pay someone to do it.
    It's closed cell.  Class I for flame and smoke spread - code accepted though needs to be covered in accessible spaces.
    It's rated at R 7.0
    they sell kits that do 600 board feet of expanded foam (600 s.f. at 1").  It comes in kits of 2 propane grill size tanks, with a hose set and nozzle/tips.
    you can spray foam all of the perimeter and up against the flooring and then finish with netted cellulose or fiberglass batts - to save some money.  the closed cell foam does it's thing by completely air sealing - as well as insulating.  it is a moisture barrier which is good for a crawl - though as I think about it you may need to put the fiberglass up first - then foam seal it all up.
    Good luck
